C Pattern Error when trying to create 'modeled' threads.
This widget could not be displayed.
I keep getting this error when trying to create 4 threaded holes with circle pattern, only when using "modeled" threads option.
(The selected faces do not form a patternable object. Try adding or removing from the selection)
Also, what's kind of strange is that last night, I'm almost sure I got it to work with three holes, but now it is not working at all.
If I try using features option, nothing at all happens.
Replies (15)
jhackney1972
In my Screencast you can see the modeled threaded holes patterns as expected.  I suggest you attach your model that is present you the error so the forum users can troubleshoot your issue.  If you do not know how to attach your model, open it in Fusion360, select the File menu and then choose Export and save the .F3D file to your hard drive. Then use the Attachments section of a reply forum post to attach it.
John Hackney, Retired
jeff_strater
it seems to work in a simple case.  Can you record a screencast of what you are doing, and share the model here?
Jeff Strater
Engineering Director
g-andresen
that´s what I see using the hole tool:
circle > extrude cut > thread  > works fine!
günther
Hi, here are some pictures trying the feature and face type, when i use feature nothing happens, and when i use faces i get the error. thanks for the support.
I've tried trying different methods of creating the hole, different sizes, different threads.
The strange thing is like i had mentioned, was that at one point i was able to do at least 3 holes modeled threads, and now i cant do any.
TheCADWhisperer
jhackney1972
It seems like you are losing your center axis reference.  You really need to attach your model as per my instructions in my earlier post.  With the model the forum users can give you a better answer.
g-andresen
You have to mark all the faces of the thread.
This is best done with a window selection.
günther
ok so here is the file.
sooooo, this is really weird, because since i left the computer and came back to create this file, it now does the C pattern with the holes but excludes the threads from the copied 3 holes. where as before it was giving me the error regardless and creating no holes.
first attechment is - create threaded hole - pattern - thread 3 holes
the second attachment is, drawing - extrude - thread - pattern - error
i am new, so excuse the noobness
i can get it work like this now, but have to add the threads to the copied holes.
g-andresen
1. As I have already written above (#4), the error only occurs with the "Identical" option.
2. follow my post #9
günther
so, here is the strange thing, last night i could not get C pattern to work like this at all, today i can get it to do the C-pattern and create the holes, but the threads aren't copied to the holes. i have to edit them in afterwards.
yes i am making sure of that
g-andresen
You have created the hole and thread separately.
Then you must also select 2 features for the pattern.
günther
this is what i am actually working on
