Bug report- Copy text in sketch drawing
mihail.hornea
mihail.hornea
So in fusion 360 when I have a drawing opened, and I create a sketch to explain something, If I have to copy some text, leader or line because I like the orientation, or the format, and I use CTRL+C, and then go out to paste it, using CTRL+V at first it doesn't show me the base point dialog box. Then, if I click outside of the feature I am trying to copy, Fusion freezes and needs to be turned off through Task manager.
Computer specs:
Intel i7 10700
RTX 2070
16 GB RAM
mohammed.aliTDPXK
Hello @mihail.hornea ,
Sorry for the trouble you are facing.
Could you please add a quick video for the issue? also would it be possible to attach the dataset here?
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
g-andresen
Please share a sample file.
File > export > save as f3d on local device  > attach it to the next post.
günther
