Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Bug from 2017 still present - Can't extrude text
30 REPLIES 30
Message 1 of 31
tsenPFFLN
992 Views, 30 Replies
It seems this bug has been present since 2017, when I search for a solution in the forums.
I can't share the file as I am working on confidential material, but I can describe the issue.
I have created a plane in an assembly and written one word with the font Soho Gothic Pro. in a height of 1,2025 mm.
I cannot extrude the text. I tried to explode the text as I read in a thread should help, but then get the error "Could not retrieve the profiles of the selected text!"
I need to extrude the text, but I'll now try with an .svg from illustrator outlines instead, but this makes the text module of fusion unusable and pointless for me.. I hope it get's prioritized and fixed soon! 🙂
Labels (2)
30 REPLIES 30
Message 21 of 31
g-andresen
in reply to: tsenPFFLN
@tsenPFFLN wrote:
again:
I cannot share a sketch as svg, only DXF. Are you not able to recreate the error with the given information? image included of the options I get when I right click on a sketch.
1. You wrote this:
The import of a SVG generates a new sketch or is inserted into an active sketch.
The SVG has no reference to the text editor but the content results (with closed contours) in a sketch with extrudable profiles.
2. I don't have this font and see no reason to install it just to answer a question.
günther
Message 22 of 31
HughesTooling
@tsenPFFLN wrote:
the one you linked is bold, I'm using the regular. Do you test it with the bold version or the regular? 🙂
Took me a while to find a regular font and the one I found is an OTF font but same problem as you, doesn't work!
Again works fine in Rhino and gives nice clean curves and surfaces.
Mark Hughes
Owner, Hughes Tooling
Message 23 of 31
tsenPFFLN
in reply to: g-andresen
I guess I'm not making myself clear, but I really don't understand what you are asking. (English is my second language, sorry).
I cannot extrude the text from fusion. I instead imported an .svg of the same text from illustrator, to have it as outlines, and that works fine. I solved the problem by doing this, and achieved my needed result.
I just think it's a shame that this workaround is needed, as this seems to be one of the purposes of being able to write text directly in Fusion.
Does that make more sense?
Message 24 of 31
tsenPFFLN
in reply to: HughesTooling
Thanks for trying this out and confirming the issue!
Message 25 of 31
@TheCADWhisperer wrote:
@tsenPFFLN wrote:
I cannot disclose the details of what I am working on, but the letters are exmoFlD
Make up dummy file that exhibits the behavior and attach the dummy file here.
If you can’t reproduce this behavior in a dummy file, how are others supposed to reproduce the issue?
Without the font file Fusion will default to Arial. @TheCADWhisperer have you got the Soho Gothic Pro font installed?
Mark Hughes
Message 26 of 31
g-andresen
Fonts are primarily created for graphics applications where no extrusion (in Z) is needed.
Therefore, it is not noticeable when the contours overlap or cross.
With extrusions, however, such "errors" can lead to problems with extrusions.
I asked the question about the SVG because I wanted to get an idea of the contour progression and possible problem areas.
günther
Message 27 of 31
TheCADWhisperer
I just Extruded the text on the file that you attached.
Oops, I need to install the font...
Message 28 of 31
tsenPFFLN
in reply to: TheCADWhisperer
that's interesting! How could that be that you can extrude it and I can't?
Message 29 of 31
g-andresen
that´s the reason:
@HughesTooling wrote:
Without the font file* Fusion will default to Arial.
günther
* installed!!
Message 30 of 31
HughesTooling
günther
Just for reference here's what I get from Inkscape. F3D file of imported SVG attached, all looks good, better than most fonts!
Mark Hughes
Message 31 of 31
g-andresen
I agree!
günther
