Boundary fill in pressure-swirl injector (problem with tangential inlet slots)
Hi!
I am a newcomer to Fusion 360, and I am currently trying to model a pressure-swirl injector in it in order to use it on CFD analysis.
The problem is that I need the volume through which the fluid particles will travel, since this is the geometry the CFD software requires for meshing. But to this moment I have not been able to get this geometry, mainly because of the tangential inlet slots (which are shown in the image attached). I have tried using Patch to cover the hole and further using Boundary Fill, but I haven't had success.
I need these slots (holes) to be filled (along with the injector swirl chamber), but I cannot find a way to solve this. If anyone could help, I would really appreciate!
Best regards
PS: I attached both an image of the injector and the injector file.
MRWakefield
Is this the kind of thing you're looking for?
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
Exactly! How did you manage to do this?
laughingcreek
attached is a model using boundary fill.
MRWakefield
Take a look at the model I attached. I'm sure someone else could've come up with a more elegant solution but here's what I did:
  1. Deleted your 'capping surfaces'
  2. Copied and pasted the body
  3. Deleted all the faces of the swirl holes and chamber to give a solid body (ie no internals)
  4. Combined (cut) one body from the other to create a new component representing the internal volume
That's it. Glad it was useful.
Marcus Wakefield
Thank you very much!
