Greetings,
When last Fusion 360 auto-updated, the bottom toolbar, normally visible in the Design screen, has gone missing.
I've uninstalled (using the Fusion 360 uninstaller ) and reinstalled 3 times using the current installer. In every case, the system appears to functions normally, except the bottom toolbar is missing. This is the one with the controls for constrained-orbit, panning, etc. Normally located to the right of the "Comments" box.
Below is a screen-shot with the cursor located where the bottom toolbar normally resided.
My System:
iMac (Retina 5K, 27-inch, Mid 2015)
MacOS 10.13.6
Autodesk Fusion360 Version: 2.0.8950
Active Plan: Fusion 360, Student
macOS 10.13.6
As I'm not supre familiar with Fusion 360, I'm not sure if this is a bug or user-error.
Any thoughts?
-Sean
My System:
MacOS 10.13.6
macOS 10.13.6
Solved by seang_fusion360. Go to Solution.
Solved by SallyYang. Go to Solution.
I have messaged the moderator because, in my opinion, the contents of messages 14 to 18 provide an excellent solution to the problem that I reported in message 13.
@g-andresen has been particularly helpful.
I was also able to change it with the Windows + arrow keys (like windows+down, windows+right and windows+up) to make the screen smaller and then back to full screen with with windows+up and low and behold it was back.
