Bottom Toolbar has gone missing
seang_fusion360
Message 1 of 24
seang_fusion360
Greetings,
When last Fusion 360 auto-updated, the bottom toolbar, normally visible in the Design screen, has gone missing.
I've uninstalled (using the Fusion 360 uninstaller ) and reinstalled 3 times using the current installer. In every case, the system appears to functions normally, except the bottom toolbar is missing. This is the one with the controls for constrained-orbit, panning, etc. Normally located to the right of the "Comments" box.
Below is a screen-shot with the cursor located where the bottom toolbar normally resided.
My System:
iMac (Retina 5K, 27-inch, Mid 2015)
MacOS 10.13.6
Autodesk Fusion360 Version: 2.0.8950
Active Plan: Fusion 360, Student
macOS 10.13.6
As I'm not supre familiar with Fusion 360, I'm not sure if this is a bug or user-error.
Any thoughts?
-Sean
My System:
MacOS 10.13.6
macOS 10.13.6
Replies (23)
Message 2 of 24
SallyYang
Did you try "Option+Command+N" to bring it back?
There is also a command under "application menu->View->Show Navigation Bar" to show/hide it.
Sally
Sally Yang
Software QA Engineer
Fusion 360 Quality Assurance Team
Autodesk, Inc.
Message 3 of 24
seang_fusion360
Sally,
Thank you for the suggestion.
No luck, however.
Application-Menu->View->Show/Hide Navigation Bar has no visible effect on the system.
Neither does the keyboard shortcut, "Option+Command+N"
To ensure there wasn't something about my Autodesk account that was causing it, I tried running Fusion360 with a Trial License, but that made no difference either.
Its starting to feel a bit like a platform-specific bug.
If there are any log-files or stack-traces which might help debug this, I'm happy to fetch them and post them here.
Sean
Message 4 of 24
g-andresen
I think it has something to do with your display settings.
günther
I have just realised that this is not the case because your timeline is visible.
Message 5 of 24
SallyYang
This is a known issue in 10.13.6. We will fix it in next update.
Sally
Sally Yang
Autodesk, Inc.
Message 6 of 24
seang_fusion360
Terrific!
In the meantime, if your developers run across a temporary workaround in the course of addressing the issue, please let the world know.
Sean
Message 7 of 24
g-andresen
some more Infos
günther
Message 8 of 24
SallyYang
Sorry, we haven't found any workaround to show it again in 10.13, but the fix should be released very soon.
Sally
Sally Yang
Autodesk, Inc.
Message 9 of 24
SallyYang
Hi @seang_fusion360 ,
We have just released a new version of Fusion 360, please update it to see if the issue get resolved.
Sally
Sally Yang
Autodesk, Inc.
Message 10 of 24
seang_fusion360
Sally,
Yes, the issue is resolved. Thank you and your team for the quick turnaround.
Sean
Message 11 of 24
nicWUZBZ
I've been using Fusion 360 for over a year now and today (or yesterday) the History and Navigation Bars disappeared!
I found this thread which suggests that a software update fixed it last time. I have just reinstalled, so has that fix been dropped?
Any help will be very gratefully received.
Cheers, 'Nic
Message 12 of 24
jhackney1972
Could this be the issue?
John Hackney, Retired
Message 13 of 24
nicWUZBZ
Hi John,
Thanks for your help but, sadly, it is not that easy. All that memu option does is change its text! In the background it is toggling something but the result doesn't reach the screen.
Also, I think I could live without the Navigation Bar. The missing History Bar is an entirely different matter! My current work is very heavily dependent on that.
Cheers, 'Nic
Message 14 of 24
nicWUZBZ
Ah ha! Very interesting. I have resolved my problem. It was to do with the Windows application screen size.
I think that (I can't really remember now) when the window was at its maximised and restored sizes, the result was basically identical, with the Navigation and History Bars off screen! Swapping between the two sizes didn't help.
However, using an ancient Windows hot-key trick, I got things working again:
- Set the window size to 'Restore'. (Make sure that the screen size button in the top right show a plain square box.)
- Use Alt-Space to get the pop-up menu in the top-left.
- Select Size.
- Now use the cursor keys to reduce the window height and width. It's a bit fiddly but, as a Fusion 360 user, you will have the necessary patience!
Once the window is a more manageable size, you can tidy things up as you wish.
Whew!
Cheers, 'Nic
Message 15 of 24
sandyturtle444
Community Visitor
Community Visitor
FAST GREAT SOLUTION TO MISSING BOTTOM TOOL BAR
Message 16 of 24
John-wilson
Community Visitor
Community Visitor
Thank you for the hack. It worked first time. What a relief!!
Message 17 of 24
minal_zunke
Observer
Observer
Can you please explain where is "windows size to restore"?
Thanks, Minal
Message 18 of 24
g-andresen
change Fullscreen/Windows screen
günther
Message 19 of 24
minal_zunke
Observer
Observer
Thanks, that works !!! What a relief
Message 20 of 24
minal_zunke
Observer
Observer
Thank you !!  guenther.andresen
this works !!!
What would be good though, is to add screenshot so people like me can understand by viewing... Thanks again. minal
