This used to work fine but lately the BOM and part drawing do not match up.
In the BOM the QTY states 4 but in the part drawing it shows QTY as 1.
Drawings attached
Is this a BUG or what?
Solved by tarkeshwar.shah. Go to Solution.
Hi Marius,
Can you please also send the drawing part browser pic, and Fusion version? And it would be great if you can send the model too.
Tarkesh
Sr. Software Engineer
Autodesk.
Thanks for the images you sent to me.
So this is not a bug, it's new behaviour of BOM/PartsList.
If you see in the Part Browser of 1st image, item number 2 ("1A" component name) has four entries, and all four are unsuppressed. That's why quantity is 4.
In the Part Browser of 2nd image, the item number 2 ("1A" component name) has four entries, but only one is unsuppressed and other three are suppressed . That's why quantity is 1.
Now the quantity of parts depends upon it's suppress\unsuppress state.
@tarkeshwar.shah Thanks for the update.
Back in the day it automatically showed the qty like in the BOM, is there no way this can still happen as for now it take time to click the box, then click the view to make it disappear but still keep the Qty.
It there is 100 parts then you will have to click 200 times for this to work. Just let the program take the QTY from the bill of material, that makes far more sense to me.
