Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Best practice to get a chamfer?
14 REPLIES 14
Message 1 of 15
InDezign
531 Views, 14 Replies
Hey everyone! 😊
I'm working on an object and was wondering what's the best approach to get the desired result.
To make it simple, I got the following body and would like a chamfer on the blue line to the outer edge (all the way around):
What's the best way to achieve a similar result like this?🤔
I tried to create a loft with two surfaces (inner "wall" and outer "wall") but I'm not convinced with the result due to some strange shapes:
I'm currently stuck and would like your help.
I attached a sample file for you.
Many thanks to everyone and best
Eric
Labels (1)
14 REPLIES 14
Message 2 of 15
TheCADWhisperer
in reply to: InDezign
@InDezign
I would start by fully defining Sketch1.
This means dimensions.
Then I would Split and Loft (or possibly Patch).
(I didn't continue with these steps as Sketch1 was not fully defined.)
Message 3 of 15
g-andresen
something like this?
günther
Message 4 of 15
InDezign
in reply to: TheCADWhisperer
Thanks for your input, @TheCADWhisperer !
Already created a loft - but as already said - it wasn't convincing.
Anyway, thanks and yes, the design is not fully defined (was in a hurry)!
Message 5 of 15
InDezign
in reply to: g-andresen
Thanks a lot, @g-andresen !
Interesting approach... but it's not going from one edge to the other.
Will have a more detailed look at your solution and maybe it's easy to extend it.
Anyway, looks like the best solution so far. 👍
At least much more convincing than my surface-loft...😊
Message 6 of 15
InDezign
Finally, your video is also available!
That's amazing... many thanks for doing it! Helped me a lot to additionally understand your approach.
Will try it myself and will let you know the result.
Thanks! 👌
Message 7 of 15
g-andresen
Please explain what you mean by this.
günther
Message 8 of 15
InDezign
That's obviously the best result ... imho.
Based on your idea, I created the above body... exactly what I wanted! 👌
Again... many thanks! 🙏
Message 9 of 15
InDezign
Just wanted a chamfer from the outer edge to the inner edge.
But based on your idea... it was pretty easy for me to solve this.
Thanks!
Message 10 of 15
g-andresen
nice to see
günther
Message 11 of 15
TheCADWhisperer
@InDezign wrote:
...(was in a hurry)!
@InDezign
This is what I would have posted several hours ago if the initial sketch had been fully defined.
Keep things simple.
See Attached file.
Message 12 of 15
InDezign
Thanks!
Message 13 of 15
laughingcreek
wgen a simpler tool than loft will achieve the end goal, it's generally better to use the simpler tool.  here sweep seems to work-
Message 14 of 15
g-andresen
in reply to: laughingcreek
günther
Message 15 of 15
InDezign
Great solution, @laughingcreek!
Thanks for your input - like it a lot! 😉👍
