Best practice to get a chamfer?
InDezign
InDezign
Hey everyone! 😊
I'm working on an object and was wondering what's the best approach to get the desired result.
To make it simple, I got the following body and would like a chamfer on the blue line to the outer edge (all the way around):
What's the best way to achieve a similar result like this?🤔
I tried to create a loft with two surfaces (inner "wall" and outer "wall") but I'm not convinced with the result due to some strange shapes:
I'm currently stuck and would like your help.
I attached a sample file for you.
Many thanks to everyone and best
Eric
Replies (14)
TheCADWhisperer
@InDezign
I would start by fully defining Sketch1.
This means dimensions.
Then I would Split and Loft (or possibly Patch).
(I didn't continue with these steps as Sketch1 was not fully defined.)
g-andresen
something like this?
günther
InDezign
Thanks for your input, @TheCADWhisperer !
Already created a loft - but as already said - it wasn't convincing.
Anyway, thanks and yes, the design is not fully defined (was in a hurry)!
InDezign
Thanks a lot, @g-andresen !
Interesting approach... but it's not going from one edge to the other.
Will have a more detailed look at your solution and maybe it's easy to extend it.
Anyway, looks like the best solution so far. 👍
At least much more convincing than my surface-loft...😊
InDezign
Finally, your video is also available!
That's amazing... many thanks for doing it! Helped me a lot to additionally understand your approach.
Will try it myself and will let you know the result.
Thanks! 👌
g-andresen
Please explain what you mean by this.
günther
InDezign
That's obviously the best result ... imho.
Based on your idea, I created the above body... exactly what I wanted! 👌
Again... many thanks! 🙏
InDezign
Just wanted a chamfer from the outer edge to the inner edge.
But based on your idea... it was pretty easy for me to solve this.
Thanks!
g-andresen
nice to see
günther
TheCADWhisperer
@InDezign wrote:
...(was in a hurry)!
@InDezign
This is what I would have posted several hours ago if the initial sketch had been fully defined.
Keep things simple.
See Attached file.
InDezign
Thanks!
laughingcreek
wgen a simpler tool than loft will achieve the end goal, it's generally better to use the simpler tool.  here sweep seems to work-
g-andresen
günther
InDezign
Great solution, @laughingcreek!
Thanks for your input - like it a lot! 😉👍
