Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
best joints to locate parametrically driven shaft in v block?
8 REPLIES 8
Message 1 of 9
rochester_rabbit
166 Views, 8 Replies
I am stumped how to position a shaft in a vee block.  The shaft dia and length are parameters and I would like to be able to have the amount the shaft sticks out one end of the v block a parameter as well.  In my mind tangent relationship would be perfect, but fusion doesn't like using 2.
8 REPLIES 8
Message 2 of 9
Sketch (in Vee Block) the relationship required.
Joint shaft to the radius line end point in the vee block.
Might help….
Message 3 of 9
You shaft can be placed in the V-Block and hang over can be controlled with three Planar Joints.  The Rod to V-Block Planar joints use Joint Origins applied to the shaft.  The retaining screw will be a different matter.  Model is attached.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Message 4 of 9
Another method is to use one Planar Joint, for the rod to V-Block hangover, and two Tangent Relationships between the rod and the V-Block sides.  Model is attached.
John Hackney
Retired
Message 5 of 9
I get this error when I do two tangent relationships
Message 6 of 9
This works. I am having a time trying to get the joint origins to orient, but I get the idea.
Message 7 of 9
I was able to get this to work too. parameters in both parts
Message 8 of 9
The message box that you show is NOT an error but a statement to you to consider.  If you agree select Continue to place your Tangent Relationship or Joint.
John Hackney
Retired
Message 9 of 9
OK.  I was concerned because if I clicked on the shaft and dragged it I got this.  Makes me concerned that tangent is not reliable.
Technology Administrators
