If it was SolidWorks 2016 you could import directly (not sure if Fusion imports 2017 yet).
Otherwise
I would use STEP (*.stp) or Parasolid (didn't check that one though).
If you use ACIS (*.sat) be sure the sender sets to ACIS v7.
Just use STEP and you should be good to go.
Attached is an example file in several formats.
I uploaded to cloud folder and then opened each format from there.
Some formats do not need to be uploaded to the cloud (just do New Design from file).
