Sharing folders
Sharing folders
hato54
Sharing folders
hato54
I need to share just one special folder with my producer.
When I'm staying in that folder and then invite, he got access to whole my project and have full read/write access to my files!
If not this i possible, is there any plans to do that in the future?
innovatenate
Autodesk Support
Autodesk Support
Sharing happens at the project level, not at the folder level.
You can create a new project that contains data you do not mind share or collaborating with.
Another option is to simply share the fusion design via a public link. You do not have to enable the download option if you simply want another person to view the design.
If you use a Fusion Team hub instead of a personal hub, you can assign users different roles and permissions.
I hope this information helps.
Nathan Chandler
Principal Specialist
hato54
Thank You @innovatenate for the information.
I still like to have this function.........
