Can you update a drawing? Can you add a page? Change the BOM scale?
I have a drawing of an assembly.
1.  I added a component to the assembly, can I update the drawing to show the new component?
2. Can pages be added to a drawing?
3. Can you format the scale of the BOM table and the Title block?
TMC.Engineering
1. yes, there is an update button that will appear next to the redo button when teh drawing is active once you save the design file.
2. Not currently, should be in the next release ~ 2 weeks see here
3. Don't think you can change BOMS yet,  I think you can use custom title block but need autocad to create the format.  someone else will know more about this
Timm
Engineer, Maker
System: Aorus X3 Plus V3, Windows 10
Plymouth Michigan, USA
Owner TMC Engineering
kris_berg
Thanks @TMC.Engineering
On #2 - We are working hard on multi-sheet, however have run into some technical challenges related to mulitsheet PDF output on the Mac.  We don't want to release anything before it is ready, so we are holding it until we have that issue resolved.  It won't be in the next few weeks, but is coming soon.
On #3 - You are correct @Anonymous can use a custom title block.  Here is a link to a video https://www.youtube.com/watch?v=7-7jLmof7A4 that will explain how you would accomplish that.
Thanks for posting!
Kris Berg
Senior Software Architect - Autodesk
