best format for importing files
Lonnie.Cady
Advisor Advisor
Lonnie.Cady
What is the best file format to use when import SW2017 files into fuiosn?  I have only worked with Native SW files and not familiar with the benefits of the different formats.
.sat/.step/.iges etc....
Thanks.
JDMather
If it was SolidWorks 2016 you could import directly (not sure if Fusion imports 2017 yet).
Otherwise
I would use STEP (*.stp) or Parasolid (didn't check that one though).
If you use ACIS (*.sat) be sure the sender sets to ACIS v7.
Just use STEP and you should be good to go.
Attached is an example file in several formats.
I uploaded to cloud folder and then opened each format from there.
Some formats do not need to be uploaded to the cloud (just do New Design from file).
Lonnie.Cady
Thank you, I was using 2016 and just importing them and never gave it a thought about 2017 until I tried and it failed.
david
so no support for SW2017?
