Baffling self-intersection issue
rnl9t
Message 1 of 10
rnl9t
I am working on a human figure (mermaid fish tank ornament) and have encountered a self-intersection error I can't figure out.
Here is the wide view with the problem area circled:Wide view of the face with problem area circledWide view of the face with problem area circled
When attempting conversion, Fusion 360 identifies this surface as self-intersecting:
Allegedly self intersecting face within eyeAllegedly self intersecting face within eye
In box mode, there are no apparent self-intersections:
Box view of eyeBox view of eye
I did some searching and learned about detached tangency handles, but those don't seem to be an issue:
Smooth view of eye with tangency handles showingSmooth view of eye with tangency handles showing
I admit I'm baffled and can't figure out what is supposedly self-intersecting.  But it is true that when I delete that face, the rest of the model converts fine, but with a hole.  So there is a problem there that I can't figure out.
Thanks!
Replies (9)
Message 2 of 10
SaeedHamza
Could you please share the file?
If you don't want it to go public, feel free to add me to you project so that I can take a look : kaksshi@gmail.com
Regards
Saeed Hamza
Message 3 of 10
TrippyLighting
It looks like you creases he T-Spline in that area. Dows this go away if you un-crease the edges ?
I've seen these issues several times when trying to convert Sub-D with more complex geometry into T-Splines. This is happens particularly in the eye and mouth area.
As this is a real pain to fix in Fusion 360 due to a lack of tools I usually resort to Blender.
Message 4 of 10
rnl9t
There are creases meeting at the corner.  If I remove all three at that corner it removes that error but also gets rid of what I'm trying to do with the shape there.
The first draft of the eye had the hollow but with the "iris" extending forward.  It was the addition of the iris that led to difficulty here.
Message 5 of 10
rnl9t
Invitation sent, thank you.
Message 6 of 10
rnl9t
Now that the long weekend is over, does anyone have any insight?  The same issue has developed on the inside corner of the eye, too, with the same non-intersection in box view and the same lack of detached tangency handles.  I'm at a loss and I haven't pushed the design forward any while I'm trying to figure this out.  I don't want to go around creating even more mysterious problems I can't solve except by deleting faces.
Thanks!
Message 7 of 10
laughingcreek
What's happening in the circled area?  looks a lot different than the smooth version, more edges and vertices.  Could just be the perspective of the pic.  I have seen multiple short edge segments appear to merge visually while in smooth mode.  Try repair body and see if you have unexpected N-gons here.
Message 8 of 10
TrippyLighting
Without access to your file this is difficult to answer.
Message 9 of 10
SaeedHamza
This is simply a N-Gons that you can get rid of by using the insert point feature from the modify menu in the sculpt environment
Here is a screencast to make things clearer
Regards
Saeed Hamza
Message 10 of 10
rnl9t
Thank you, that did it!  I'm now off to create many more problems that will confuse me.
