Autodesk fusion 360 crashing
Message 1 of 9
Recently my autodesk fusion crashes when i create drawings from existing designs, and also crashes and stops responding when i try to open or delete any of the drawings created from existing designs. Please help me find a solution to this issue.
Thanks.
Huber Mayanja
Replies (8)
Message 2 of 9
PhilProcarioJr
Get your diagnostic logs from your computer and post them here so Fusion team can take a look at them.
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 3 of 9
Hi Phil,
i have attached the diagnosticlogs.
Message 4 of 9
kris_berg
Hi @Anonymous,
Thank you for posting. I am sorry you are having this issue.  After reviewing your logs and your Crash Error Reports (I did not find any) I need some more information from you.  When you say the application crashes, can you send me (kris.berg@autodesk.com) an image of the dialogs you see when the application crashes?  It will help me further pinpoint the issue.
Thank you,
Kris Berg
Fusion 360 Development
Kris Berg
Senior Software Architect - Autodesk
Message 5 of 9
Hi Kris
anytime i try to open or delete the atttached type drawings the computer gives a not responding message and crash the programme and too when i try to save my drawings it does the same thing.
I have unistalled and reinstalled the programme but still get the same issue.
thanks for your help in trying to get this issue resolved
Huber Mayanja
Message 6 of 9
kris_berg
Hi @Anonymous,
Thank you for the pictures.  You mention above that you see this when creating a new drawing.  Can you try creating a simple design (box) and creating a drawing from that?  If you can not create a drawing from a simple box can you follow these directions for a clean uninstall/install?  https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-do-a-clean-uninstall-of-Autodesk-Fusion-360.html
Thank you,
Kris Berg
Kris Berg
Message 7 of 9
Hi Kris
I did the clean install and still no luck, im still having the same issue, i have not figured it out yet
Huber
Message 8 of 9
yoshimitsuspeed
Have you tried restarting your computer?
I have had a number of times where I had an issue with F36 that I just couldn't figure out and then restarted and problem went away.
I wish I could be of more help but sometimes it's the simple things.
https://www.facebook.com/groups/1229995573786339/
Message 9 of 9
kris_berg
Hi @Anonymous,
I am sorry you are still having problems after following the clean uninstall/reinstall procedure.  After rebooting your computer, can you try opening/creating a drawing again.  Then go to Task Manager and see if there is a process named "AcCoreConsole.exe".  Let me know your findings.  Also what OS are you running on?
We have seen some problems in the past if people have key scrambling applications.  Here is a related post http://forums.autodesk.com/t5/design-validate-document/no-drawing-created/m-p/5768901#M30412 .
Thank you,
Kris Berg
Kris Berg
