- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying the "create drawing from design" option on a current project and it is failing. The drawing Tab is created, but no document "canvas" is made visible. If I push any button on that tab, Fusion moves to "(not responding)". I have noted using a task manager that when I invoke the "create drawing from design" option, the process "AcCoreConsole.exe" starts up at about 12% of my cpu cycles, but never completes or varies after that. If I get into the "(not responding)" state, I can recover response from Fusion by deleteing the task "AcCoreConsole.exe".
To date,
- I have cleared the user cache. RESULT::still fails
- I have updated all of my video drivers, rebooted and reinstalled Fusion 360 version 2.0.1574. RESULT:: still fails
(I used the deinstall procedure that used Windows de-install of app followed by deletion of many specific directories)
- I have used a simple cube design (rather than my original design) to attempt to create a drawing. RESULT:: fail
- I have dropped back my preferences to use DirectX version 9.0. RESULT:: still fails
I am running Windows 7 64 bit. A copy of my Diagnostic Logs that should contain this morning's most recent failure is attached.
Can anyone help me?
