Autodesk Expert : Save and Quit not functioning??
Message 1 of 8
As to be seen on added screenshot I have since a 25-02-17 problems  with save and quit.
Someone out there who can solve this? maybe an Autodesk Expert??
regards,
Pieter
Replies (7)
Message 2 of 8
Roman_Vesely
Hi Pieter,
 your documents are pretty big (2 052 572 KB total) and this isn't an error. This dialog only says that your documents will be uploaded to cloud and Fusion will be closed afthet that.
Is the performance of the Save / Upload process a problem which you have ?
Regards
 Roman
Roman Vesely
Inventor - Principal QA Engineer
Message 3 of 8
Hi
I now see in my DATA panel HULL CLOSED PROFILE v25 is not visible - missing ?? -.
Now opening HULL CLOSED PROFILE v24 which is busy already 20 minutes now.
To overcome this issue I want to delete v2
But first I would like to export v24 to my PC
However I have to wait if uploading to my PC will be  completed successfully.
regards,
Pieter
Message 4 of 8
Message 5 of 8
Screencast
Message 6 of 8
screenshot
Message 7 of 8
Save and quit 5.PNG  last screenshot
Last screenshot File v3 now available
Message 8 of 8
Roman_Vesely
Hi Pieter,
 it seems to be a performance problem with saving of big files into the cloud storage. Unfortunately, you can't delete particullar version of your design document. You can delete only the whole file. Not available message in Data Panel means, that the latest version hasn't been uploaded to cloud yet. It probably happened when you created new version, saved document and closed this document.
For debugging purpose of this issue ... could you invite me (with my email address: roman.vesely@autodesk.com) into your project, please ?
Thank you
 Roman
Roman Vesely
