Fusion 360 Mirror function not activated
Hallo.
I have Fusion 360 problem With the Mirror command buttom not activated. what is the reason?
HughesTooling
If you're trying to mirror sketch entities you need to make sure you are in sketch edit mode. If you're trying to mirror bodies\components you need to use the mirror feature on the Modify menu.
Mark
Mark Hughes
Owner, Hughes Tooling
Hello. Thank you very mutch for usefull information.
Regards Rune.
Sendt fra E-post for Windows 10
