Duplicating a sketch on a plane around an axis
Hello, I have a body, imagine a very thin cylinder, and I want to extrude strips from it all around, easiest to show you an example:
So the circle here would be the body, and the thin rectangle a sketch of the area I want to extrude from the body, however I want it to go all around sort of like this:
Is there a way to duplicate and rotate a single sketch in this fashion? I could do it manually but I will most likely need to redo it with varying widths and lengths so it would take forever. Thank you
davebYYPCU
Use Sketch > Pattern > Circular pattern, to "copy" the rectangle around the centre of the circle, no need to make more sketches
but recommended practise is to extrude the first leg, on the cylinder, then
Create > Pattern > Circular Pattern - solid bodies
Fusion balks at complicated sketches, yours would not be complicated, but bodies are more efficient.
might help
