So I have made a somewhat complicated wood structure, and used the auto arrange function to make 3 flat pieces for the wood shop. It works great.
But now I have a lot of small pieces, and even me is having problems identifying what is what. It would be useful if the auto arrange could do something to label all the pieces with the name of the component the body came from
Also, as a suggestion, if I could export an arrangement to DWG or DXF, not only STEP, IGES etc.
thank you
Solved by Warmingup1953. Go to Solution.
Mapboards Pro (Paid Add-in) may work for you....
https://youtu.be/BmuxxvIU2XA?si=OlrFZdXp3xoGhpFI
For complex nesting (and admittedly not for Fusion 360 output) I use an Online Nesting site (Free to 50 Parts)
It creates Nested .dxfs and excellent report .pdf
