Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
auto label arranged bodies
1 REPLY 1
rprovideo
111 Views, 1 Reply
So I have made a somewhat complicated wood structure, and used the auto arrange function to make 3 flat pieces for the wood shop. It works great.
But now I have a lot of small pieces, and even me is having problems identifying what is what. It would be useful if the auto arrange could do something to label all the pieces with the name of the component the body came from
Also, as a suggestion, if I could export an arrangement to DWG or DXF, not only STEP, IGES etc.
thank you
1 REPLY 1
Warmingup1953
in reply to: rprovideo
Mapboards Pro (Paid Add-in) may work for you....
https://youtu.be/BmuxxvIU2XA?si=OlrFZdXp3xoGhpFI
For complex nesting (and admittedly not for Fusion 360 output) I use an Online Nesting site (Free to 50 Parts)
It creates Nested .dxfs and excellent report .pdf
Technology Administrators
