Authentication error when launching Fusion 360
Message 1 of 22
Getting this issue when trying to run a trial version of Fusion 360 on my Windows 7 PC. It is a corporate PC.
"The application has encountered an unexpected authentication error and must be quit."
I had previously installed and run Fusion 360 on this PC a few months ago, then deleted it. This new version was downloaded using a commercial promo code.
I have tried downloading and installing using my home wifi (no proxy) as well as through corporate network, which does use a proxy. Get same issue both ways. I can log in to https://myhub.autodesk360.com just fine.
Any help would be greatly appreciated. Thank you!
Kevin
Replies (21)
Message 2 of 22
innovatenate
Autodesk Support
Autodesk Support
Welcome to the Fusion 360 Community! Sorry to hear about the difficulties getting Fusion 360 to run or install.
You mentioned that you isntalled and ran a previous version of Fusion 360 on the machine. It may be a good idea to perform a clean uninstall of the program to wipe the machine clean. The below link details the step by step instructions for a clean unisntall.
http://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-...
If the issue is ongoing, it may help to review the installation log file.
http://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Unab...
I note that there is a 407 error that can be located in install log if the issue is related to the proxy.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Err...
If you are have environment variables for the proxy at work, you may consider removing these for use on the home network. The environment variables may look like the ones in the below link.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Ins...
I hope these suggestions help, please keep us updated on your progress.
Nathan Chandler
Principal Specialist
Message 3 of 22
Turned out I only needed to run the application as an administrator to get it to work. I think my computer was reconfigured between the initial successful test and getting this error - something that made it so the default "open application" action was set to happen WITHOUT admin access.
Thanks for the suggestions Nathan!
Message 4 of 22
Hello, I get the same problem. I try to solve the issue with some possible solution here but I cant to find the right one.
I install the Autodesk Fusion 360 in my house (without proxy) and it works fine. After that, I try to use this software in my college (the network there is using proxy and authentication such as username and password) and it works fine. After that, I go home and try to use this software but the error happen with message "the application has encountered an unexpected authentication error and must be quit". Is it because I use proxy before? How can I solve this issue?
Thank you very much
* Sorry for english
Arif
Message 5 of 22
innovatenate
Autodesk Support
Autodesk Support
In the Control Panel >> Interenet Options >> Connections tab >> LAN settings >> Do you have automatically detect settings enabled?
You may also consider testing the below procedures:
1. (Close Fusion 360) In windows explorer browse to %localappdata%\autodesk\web services
2. In the Web Services directory, right lick on the Login State.xml file and select delete
3. Restart Fusion 360
Also, this procedure:
1. (Close Fusion 360) In windows explorer browse to %appdata%\autodesk\nuetron platform\options
2. In the Options directory, right click on the NMachineOptions.xml and select delete
I hope this helps. Let me know if you have any questions.
Nathan Chandler
Message 6 of 22
Thanks innovatenate for help! The problem is over when I re-install the software
Best Regards,
Arif
Message 7 of 22
hi Nathan, i also experience a simalar problem when launching fusion 360 on my macbook pro, what can i do to resolve this issue?Screen Shot 2015-12-05 at 2.00.11 PM.png
Quincey
Message 8 of 22
innovatenate
Autodesk Support
Autodesk Support
Is the Time and Date settings on the computer correct? Can you try reseting them to match your current time zone?
You may also try unchecking the auto proxy discovery settings in the Network Preferences in the Mac OS.
If this doesn't help, can you share the application log files here?
1. Open Terminal window and type the below command
open ~/Library/
2. Browse to ~/Library/Application Support/Autodesk/Autodesk Fusion 360/logs
3. Compress the log files and attach them here for further review
Nathan Chandler
Message 9 of 22
hi Nathan
The time and date settings are correct,attached are my compressed log files. hope to hear from you soon.
Message 10 of 22
innovatenate
Autodesk Support
Autodesk Support
I note log files contains curl errors:
6, "could not resolve host," for an autodesk360.com website.
28, "Connection timed out after 20000 milliseconds" for an autodesk360.com website.
This appears to be a network connectivity issue preventing Fusion 360 from authenticating with Autodesk services.
In a web browser, can you access and sign into the below website?
Have you tried testing with the firewall disabled?
  1. Choose > Apple menu > System Preferences, then click Security & Privacy
  2. Select Firewall > Turn off
  3. Re-Test
Are you using anti-virus software?
Is it possible to test from another network?
I hope this suggestion helps. I look forward to your reply!
Nathan Chandler
Message 11 of 22
hi Nathan
I signed into the website you said I should, is it something that'll help me with the issue? I also tried connecting with a different network, the fire wall has been off it still shows the authentication error when launching, what do I do?
Regards
Quincey
Message 12 of 22
innovatenate
Autodesk Support
Autodesk Support
The website is just a diagnostic test to see if you can access autodesk360.com from a webbrowser.
Did you try changing the proxy settings I mentioned in the previous post enabling/disabling auto proxy detection?
Nathan Chandler
Message 13 of 22
Im having the same problem. I had installed the software and had used it for a few weeks. Yesterday i had created an adhoc network using cmd. I disabled it after i was done. Since then my software is not opening and it says that there is a authentication error and must be quit. I have tried all the solutions that i could find and the proxy tweaks too, but it hasn't helped so far. Pls help me.
Message 14 of 22
innovatenate
Autodesk Support
Autodesk Support
Are you seeing the error message reported in the below link?
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fus...
It may also help to try this suggestion (if you haven't yet).
Please let us if there are any questions. I hope this helps!
Nathan Chandler
Message 15 of 22
I tried, but it didn't help. Should I uninstall and reinstall the whole software?
Message 16 of 22
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
I just replied to your main thread (link here) with some suggestions! Let's try to work in that thread as it is newer.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 17 of 22
I solved this by plugging in my phone to my work computer and using USB tethering on my phone to get around the proxy.  Worked like a charm!  Check google to see if your phone has this option and how to use it.
Message 18 of 22
Hi!
Today the  "Fusion 360 unexpected authentification error" hit me.
The Log Stated following Error:
2016-11-23 22:49:40,665 - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is XXXXXXXXXXXXXXXXXXXXXXXXX ---- stream is production ---- global install is False <<<<<<<<
Solution was to change in the "FusionLauncher.exe.ini" File the Line
global = False
to
global = True
and Fusion Launches again!
Maybe this could be helpfully for someone else,
Greetings,
Sebastian
Message 19 of 22
please help
Message 20 of 22
innovatenate
Autodesk Support
Autodesk Support
@Anonymous Please give the suggestions in the below link a try.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fusion-360-sign-in-failure-due-to-service-outage-unexpected-authentication.html
If that does not help, it will be necessary to review the log files from your computer see the below locations.
C:\Users\%USERNAME%\AppData\Local\Autodesk\Webdeploy\Web Services\Log\
C:\Users\%USERNAME%\AppData\Local\Autodesk\Autodesk Fusion 360\%USER SPECIFIC ID NUMBER%\Log\
If the link does not help, please share the log files stored in the above directories so we can review the issue further.
Thank you,
Nathan Chandler
