Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Australian Standard steel
1 REPLY 1
494 Views, 1 Reply
Hey all,
I'm hoping somewhere there is an Australian Standard for steel library I can download from somewhere for Fusion 360?
The material weights and appearances are all wrong and I was hoping to not have to customise anything as it is quite time consuming.
Thanks!
1 REPLY 1
jhackney1972
You can find DXF drawings that can easily be imported into Fusion 360 at this website.  They create the DXF as a composite of all sizes for similar sections.  After using the "Insert DXF" command, you will see a lot of sketches drawn on top of each other, with a common reference.  Simply turn off the ones you do not want.  Once you find the sketch, you can extrude it to the length you need.  I do not know Australian Steel from a hole in the ground so I hope the sketch names can assist your selection.  Here is a screen capture of some of the equal leg angles to show you what I mean.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
