Hey all,
I'm hoping somewhere there is an Australian Standard for steel library I can download from somewhere for Fusion 360?
The material weights and appearances are all wrong and I was hoping to not have to customise anything as it is quite time consuming.
Thanks!
You can find DXF drawings that can easily be imported into Fusion 360 at this website. They create the DXF as a composite of all sizes for similar sections. After using the "Insert DXF" command, you will see a lot of sketches drawn on top of each other, with a common reference. Simply turn off the ones you do not want. Once you find the sketch, you can extrude it to the length you need. I do not know Australian Steel from a hole in the ground so I hope the sketch names can assist your selection. Here is a screen capture of some of the equal leg angles to show you what I mean.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
