04:07 AM
I downloaded a Grabcad model (https://grabcad.com/library/flower-monstera-001-1) and loaded it into my Fusion 360 project. After making some changes I tried to apply different appearances to the different bodies/surfaces. My problem is that the appearence of the inner leaves only change one side of that leaf. No matter what function I use (changing appearance on a body, component, surface; changing physical material) I can't seem to change the appearance on one side which allways keeps this 'gold' color'.
Am I overlooking something obvious here?
Attached is my file.
Link copied
