Appearence only changes one side of a surface
I downloaded a Grabcad model (https://grabcad.com/library/flower-monstera-001-1) and loaded it into my Fusion 360 project. After making some changes I tried to apply different appearances to the different bodies/surfaces. My problem is that the appearence of the inner leaves only change one side of that leaf. No matter what function I use (changing appearance on a body, component, surface; changing physical material) I can't seem to change the appearance on one side which allways keeps this 'gold' color'.
Am I overlooking something obvious here?
Attached is my file.
g-andresen
This is expected behavior. Bodies 3-5 are faces.
To do: Thicken them minimally and deactivate the faces.
günther
artemSIV
Hello, I hope this video helps you figure it out. The solution is to create a body from the surface.
I've made it work. Thanks @artemSIV for the video 🙂
One question though. Why is that one side of a surface (something that has no thickness) always keeps this gold color no matter at what level (component, body, surface) I force an appearance?
jeff_strater
The yellow side of a surface is the "back" side (away from the surface normal).  You can disable it here:
Jeff Strater
Engineering Director
That's the setting I was looking for! Thanks
