How to use Straighten feature in Form mode?
travis.designer.vn
travis.designer.vn
Hi
I create a Plane, 3x3 faces
Then I move 2 vertices. details in picture:
How can I use Straighten feature in form mode? I intent to make it sketch edge as previous.
Replies (10)
g-andresen
take a look here
straightenstraighten
günther
travis.designer.vn
Thank you.
There are 3 option
The minimum number of vertices per surface depends on Direction type:
  • Fit: 3
  • Select Line: 1
  • Select Parallel Line: 2
Can you give demo Select Line and Select Parallel Line?
Thank
travis.designer.vn
Hi
I try Direction: Select Line.
I draw a line. Then try to pick this line but can not pick. What I should do?
laughingcreek
I think the term "line" in the command is miss-leading.  you can only pick the edges of bodies, no lines. (and the you pick have to be straight)
@jeff_strater  - can the UI folks look at this?  between the confusing terminology (line instead of edge) in the command, and the lack of explanation in the documentation, it seems like this could be improved on some.
travis.designer.vn
@laughingcreek
I agree with you. There are confusion.
I try draw new Axis throught 2 points. Then I can pick this Axis.
travis.designer.vn
Hi @laughingcreek
If I need 2 fix points. How can I use Select Parallel Line?
laughingcreek
I use t-splines (form) a lot.  I personally wouldn't obsess over the use of straighten line.  I don't really see it as being that useful.  there are a lot of other important things to learn about using this environment.
TrippyLighting
Completely agree!
travis.designer.vn
Hi
I agree with both of you. However I think the Fusion 360 Team have reason to create this feature. Today, I can apply option Line and Select Line.
I just want to undestand Select Parallel Line. They may help in future.
jeff_strater
This limitation has been fixed in our internal build.  You will soon be able to select a sketch line in the Straighten command.  It will be appearing in an update soon.
Jeff Strater
Engineering Director
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
