Appearance Disappears When Importing Into New Design
ChristopherMarion
Advisor Advisor
ChristopherMarion
Hi All,
I am having an issue with a parametric vise I am trying to create on the design side for my setups for manufacturing.  When I change the appearance to the faces or to the entire component, it looks just how I like it.
Now, if I bring that vise into a new project and I break the link, most of the faces lose their appearance.  I cannot figure out why this is.  Has this happened to anyone else?
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
jhackney1972
I cannot replicate this issue on any of my models.  Could you please attach this problem vise and let the forum users try it out?
John Hackney, Retired
ChristopherMarion
Hi @jhackney1972
Here it is ............. https://a360.co/3l9Qytf
To replicate:
  1. Create a new project
  2. Insert into current design
  3. Break the link
Only the black faces remain.  All others revert back to the original solid colour.
Christopher Marion
SolidCAD - Canada
jhackney1972
Your model will lose its assigned Appearance, as you said, when Inserted into another assembly and then break the link.  However if I edit the Appearance on two surfaces, using one of your colors, save it, and do the same process, it DOES NOT lose the appearances I applied.  I will continue to look but I am currently at a loss.  @jeff_strater , do you have any ideas?
ChristopherMarion
Hi @jhackney1972
Strange indeed.  I've done this many times in the past without issue.  I've tried changing appearance on the top level as well at the component level.
I did find that if I remove the "default" appearance from the design that it also fixes it.  It's like the default is still being forced over what I've applied once I break the link.
Anyway, here is a recording if you want to see what I mean.... https://autode.sk/3vus16E
Cheers,
Christopher Marion
SolidCAD - Canada
