Align Sketch to body not working(?)
Message 1 of 13
Hi, I'm a bit new from Fusion 360 but I do have a question about the align tool. I'm trying to align a sketch to a body. The tool is working till I press ok. then the sketch return in his original position. Any idea of what i'm doing wrong? Cheers
Screenshot 2018-05-10 09.03.43.jpgScreenshot 2018-05-10 09.03.35.jpgScreenshot 2018-05-10 09.03.14.jpg
Replies (12)
Message 2 of 13
lichtzeichenanlage
IMHO you don't want to move your sketch but you want to sketch on the target body. This works as long as the faces are planer. If they aren't other techniques like construction planes and projection or sheet metal comes into place.
This example shows how to sketch on a body.
Message 3 of 13
Thanks for your reply.
But I need to center the rectangle on the cylinder.
Message 4 of 13
g-andresen
Hi Andrea,
the align tool only works with bodies and components.
günther
Message 5 of 13
lichtzeichenanlage
What do you mean with center? Centered between the bottom and the top face of the cylinder? Center of the rectangle aligned with the center of the the cylinder on the e.g. top face?
Message 6 of 13
Yeah your right, sorry to be inaccurate. I mean, the center of the rectangle aligned with the center of the the cylinder on top face (where the rectangle is drawn)
Message 7 of 13
lichtzeichenanlage
Here are some more examples. Screencast is uploading will take some minutes for AD to process it.
Edit: But the main answer ism still: Draw on the faces and use constrains to align you stuff.
Message 8 of 13
lichtzeichenanlage
Here is your screencast
Message 9 of 13
lichtzeichenanlage
The last example is nonsense. I thought I've edited it out but somehow I didn't. Sorry for the confusion.
Message 10 of 13
daniel_lyall
@lichtzeichenanlage you can report your self to admin and ask them to remove the post
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 11 of 13
lichtzeichenanlage
@daniel_lyall: It was the last part of the screencast. The post is still valid. And unless I can't edit the screencast anymore everything is fine. I'm human - I make / have errors 😉
Message 12 of 13
chrisplyler
LIES! ALL LIES! You are a rough, German robot.
Message 13 of 13
lichtzeichenanlage
If just finished a bunch of Google I/O videos and I've to admit... you could be right 😉 Just search for "A Google Assistant that will even make calls for you"
