Algebraic operators not working in "Change Parameters" dialog boxes
I'm running on a Mac with High Sierra and Fusion 360 version 2.0.3803, But I can't put an equation into the "Change Parameters" dialog box. Simple ones work (e.g. r+2), but I want pi*r^2, and can't even get r^2 or r*r to work. I think that "pi" should be a constant, looking at the examples online.
Any Ideas?
Accepted solutions (3)
rohit.bapat
Hello @Anonymous
I don't think we have a 'pi' as constant. You may create a parameter named 'pi' = 3.14 (or more digits according to need)
As far as r^2 or r*r is concerned the problem is that for example if you have a parameter of units 'mm' and you are trying to set it as mm*mm for example
r = 5 mm
Param1 (mm) = r*r
This will cause issues because r*r is mm^2
You can solve this by simply putting
Param1 (mm) = r*r/mm
Is this the case you are running into?
I might be able to help in this case to solve it.
Thank you,
Best Regards
Rohit Bapat
Rohit Bapat
Product Owner
Yes, that fixes the problem.
Thanks so much for your help.
HughesTooling
PI is available needs to be all caps, PI
Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Here's another example for your PI*r^2 problem
Mark Hughes
