@TheCADWhisperer, The DXF drawings I receive from clients are quite simple,  but I never had a file that I should extrude just once, each drawing I got, needed more than one extrude operation, and I don't think for simple objects I need to make multiple sketches . And it's not about the drawing being imported from a DXF file, but I think most simple objects that are designed in Fusion don't need many sketches, or more than one. When I draw a case for something, I'm making most contours on the "main" sketch, extrude from there, and after that add more sketches for the sides or bottom side, if it's needed.
Please don't get me wrong, I'm not pissed off because I need to click the light bulb, one more time, it's not that big deal (it's quite easy to get used to it, as @davebYYPCU told, I'm more pissed off because Fusion is not importing texts, but this is another story) but in my case it's a feature that it shouldn't be active, and the main reason I opened this thread was to understand why it was even implemeneted because in my case, it's not helping (I'm sure this auto-hide feature was implemented to help users - I wanted to know in which cases)  .. Now I understood, when I read davebYYPCU second reply, I understood that on complex designs, it's better to have many simple sketches instead of one sketch containing all the contours.
@jeff_strater awesome news Jeff ! Thank you for letting me know, this is the perfect way to solve this "issue" ... some users need it , but some don't, I'm sure it should be quite simple to be implemented also.
