After Copy-Paste New, How to Dimension?
rossjm5075
rossjm5075
If I Copy a Component, and then Paste New, I don't have access to the Sketch/Extrusion Dimensions in the timeline for the new Component. How can I parametrically dimension the new Component? Thank you!
jhackney1972
If you create your components, using Rule #1, which places the component sketch below the component, the editing of the new Paste New component will not be an issue.  The Screencast will explain.  I attached the model I created, as you can see the timeline offers the ability to edit.
John Hackney, Retired
rossjm5075
Ahhh, I see. Many thanks and much appreciated. I had created a Body, and then converted it to a Component, so the sketch was outside of the Component, and thus didn't copy over when I did the "Paste New". Your reply clears this all up!
