Need a better way to position in sketch
javelin_exile
javelin_exile
So I'm working on a device where I have to position rollers for a web of material that flows through it. I'm in a 2D sketch now, and these sets of rollers have 2 positions when in use I know the positions for all of the rollers except one, and what I have done in the past in other Cad programs is have driven dimension for the position of the last element nd I could just drag it to where it needs to be
jhackney1972
You seem to be wishing for a way to drag a sketch, of a roller diameter, using a sketch guide path.  You can create this in a number of ways, my Screencast shows one.  Be more specific in your need and the Forum users can give you a more precise answer.
John Hackney, Retired
jeff_strater
driven dimensions are supported within a 2D Fusion sketch.  But, if you share more about your desired outcome, we can better answer your question.
Jeff Strater
Engineering Director
javelin_exile
@jhackney1972  @jeff_strater  Thanks for your replies.  Maybe this explains my question better. I did work this out but in a more convoluted way that is not what I was used to in other CAD programs and thought It would work the same in Fusion. This diagram shows the problem. Line 1 and 2 in use, have to be the same length when roller #2 is in the upper or lower position. It's actually the distance from roller 1 to a cutter that is represented by the lone arc at the lower right, when it's in the upper position the end of the web only to be at the top of the roller.  What I'm trying to determine is the proper position for roller #1 to give the same line length in the 2 positions. This is oversimplified in the sketch because there are other objects interacting with the web between the 2  when the arm that controls this moves from position 1 -2.
What I would do when doing this before would be to have a dimension that is the total length of the line as a driven dimension that I could watch as I dragged the roller around so it became easy to determine the best position for it. That's what I am missing, I can only get driven dimensions of line segments. not of a whole bunch of segments.roller pos.JPG
stiller.design
is this just a rotation? you can apply the constraint EQUAL to the lines, that will keep them at the same length.
it looks like this can be "easily" solved in 1 sketch
davebYYPCU
You haven’t given us enough information, and your blue diagram, needs to turn black sooner or later.  You need a path for circle 1.
John has circle 2 sorted with a travel path, defined.
This latest diagram appears to have two hinged lines moving circle 1, dependant on the hinge angle.  Put the driven dimension on the 2 circle centres.
Might help....
