Delete a file or a folder
donato.scricca
Message 1 of 8
donato.scricca
Hi, the software doesn't permit me to delete  files or a folder doing right button mouse and later delete. I attach the message that I obtain.
How can I do?
Replies (7)
Message 2 of 8
TrippyLighting
The glare on your screen makes the image very difficult to read.
Windows and macOS have built in tools to create screenshots, so you can forego the use of a phone.
Message 3 of 8
aliobidi
Hi ,
see this might help
Message 4 of 8
donato.scricca
Sorry, distraction. I attach the image
Message 5 of 8
g-andresen
have a look at this tutorial by @jhackney1972
günther
Message 6 of 8
donato.scricca
Sorry, why doesn't the software allow me to delete a folder?? I only have 10 saves and I don't need this folder.
Thanks!
Message 7 of 8
donato.scricca
Sorry, I have attached the image regarding the reply of the software. Unfortunately the reply is in italian because I have Fusion in italian. Can you help me the same? I have to delete the folder. The reply of the software is regarding the production, but I don't have still make nothing.
Many thanks and I hope in tour help
Message 8 of 8
johan.rutgeerts
You cannot delete files or folders if they are referenced by other files or folders.
E.g. you cannot delete a component if it is used in some assembly, unless you first delete the assembly.
And this counts across all versions.
E.g. if you have:
- Assy1 V1 contains Component1 and Component2,
- Then Component1 is removed from Assy1 and Assy1 is saved (yielding Assy1 V2).
- You will not be able to delete Component1 unless you first delete Assy1, even though Component1 is not in Assy1 anymore. Since it is still referenced by Assy1 V1.
This is not something typical for Fusion 360, e.g. in Windchill it is exactly the same.
Technically, it is of course not impossible that a "delete this file/folder and anything related to it"-functionality is implemented, but this does not currently exist.
The workaround I use is to create a project named 'Garbage'. In that project, I create a subfolder per year (e.g. 2022). Instead of deleting files and folders, I move them to that folder. The reason I use a subfolder per year is that over time you won't get one large folder with very many 'deleted' files in it.
Ideally the Garbage project would be created by an admin and given 'write' but no 'read' privileges, so users can move to that folder but not search and find any files afterwards (so to the user it seems as if the file really is deleted). I don't know if this is possible in Fusion 360.
To some people this workaround seems very counter-intuitive, or even plain wrong, since the files – which you know you do not need anymore – will never really be deleted. But it works, so I choose to quit philosophizing about this and focus on more impactful issues.
Johan
