Advice. V-22 Osprey aircraft
5 REPLIES 5
cdotrodrigues
366 Views, 5 Replies
Hello all,
I would like to model a V-22 Osprey aircraft. I have some high quality canvases. What would be the best approach to model with the final objective of 3D printing using Fusion 360? Some pictures in attach. Thanks
5 REPLIES 5
How many projects involving complex lofts and / or T-Splines have yo completed in Fusion 360?
Can you provide some example models, so we can assess where you are skill wise?
I made some exercises with t-splines and lofts but my experience with T-Splines and surfaces is not much. Made simple things like vases, some rc parts like naca intakes, propellers... but nothing complex.
some things I´ve made using loft1.jpg2.jpg3.jpg4.jpg5.jpg6.jpg1.png5.png1.jpeg
davebYYPCU
in reply to: cdotrodrigues
Start with a common Datum for the Canvass,
size is first consideration, build 1:1, scaling and resizing is not a smooth operation after the fact.
Build one and mirror the other side.
Build outlines first and add detail later.
Might help...
@cdotrodrigues I think you've got enough experience to dive right in!
I see you posted this on the Fusion 360 facebook group as well. Someone mentioned that this looks like individual shapes blended together. That is correct!
I made a  video on a simpler example a while ago that was also based on a Forum post.:
If you are going to attempt doing some, or all of it with T-Splines I can recommend Gichi Endo'syoutube channel. He is a professional vehicle designer and  it shows in his videos.
Also I would recommend Arrimus 3D for Sub-D modeling, which is very close to modeling with T-Splines. He uses different software tools (mostly 3DS Max, some Blender) , but the general concepts still apply.
I would agree with the one poste (Andreas Los Del Tripos) on the Facebook group that modeling with T-Splines (Or Sub-D) can take a while top learn, but IMHO it  is a very good skill to have! it's also a lot of fun.
