Hi Community
I am currently trying to advance my FEA of a Plastic/Metal Part combination. I want to study the pressure distribution around a metal Pin that contacts a plastic socket. Now as always I start of easy and use bonded as first approx. to check model support for overconstrained behavior. ✔ this is shown in load case "bonded definition"
Now I'd Like to study the situation in the pin/hole contact surface with a more realistic separation contact.
Unfortunately the error messages appearing here are unspecific and no geometric representation of the failure area is available.
Does anyone have a recommendation to "tune" the contact parameters
to be honest the difference between bonded and separation contact here will be rather small.
We do not expect a huge movement pin inside the hole. But it could slide a little inside. So the full separation contact could be too complicated if we expect the movement only in one direction. So I will try with separation contact on the end face of the cylinder and sliding with the cylindrical one.
If that does not help. Attach the simulation file. You could use the link or standard export to f3d 🙂
BR
Karol
