- Mute
- Permalink
- Report
Hi All,
My current project is for a ducted fan and I am creating the blades. I can get a very nice
standard loft with profiles and simple rails. The problem is creating a very complex 3d
curve to replace these standard rails. Things were going a little slow but forward when
the person came back and said they had an STL file of a similar "Rolls Royce Turbine Blade".
I only have basic experience when it comes to IMPORTING an STL and manipulating it but
I am confident I can turn it into a usable solid. The blade profile will be very different to
this STL but I do want to use the leading and trailing edges of this model to re-create the
curves to use as rails. How would I do this?
It is a complex 3d curve so I cannot just bang down a plane and create the curve with a
projection. Is it possible to use the edges of the STL model as my rails? How do I create
a 3D sketch from the STL so I can use this line as the rail?
Any other advice on how to reproduce these curves would be appreciated.
I don't yet have the STL, otherwise I would attach it. The blade profile is a
simple 3 point spline.
I can't post my design file as I don't have permission to share.
Cheers
Andrew
