Broken, annoying faces
20220374D3DY
20220374D3DY
Screenshot 2025-07-23 221911.pngScreenshot 2025-07-23 221920.pngEither im poor at modeling or its fusion not generating faces correctly, there are multiple faces that are just hard to discribe. They shouldnt even exist and keep bugging out when editing other faces. I may have used loft too many times.
jhackney1972
Without your model, there is very little help that can be given.  Please attach it.
John Hackney, Retired
g-andresen
1. Unfortunately, the screenshots are not sufficient to respond to your request.
2. Please upload the file and describe which areas (functions) are involved.
File > Export > Save locally as f3d > Attach to post
günther
Please embed images in the text.
This makes it easier to read without having to click.
johnsonshiue
Hi! The quick thing I would try is to select the face and hit Delete key. Does the face go away?
Many thanks!
Software Test Engineer
20220374D3DY
No, it creates an error or messes up the gemoetry of the part.
20220374D3DY
The .f3d file requested
johnsonshiue
Hi! Many thanks for sharing the design! I took a quick look. The undesirable intersections are rampant on the model. It will take lots of efforts to clean up. I personally think it would be better to recreate it from scratch using Surface Modeling technique.
The intended model is thin body generally. Usually, the designer would focus on exterior shape first without worrying about interior details. The Solid Modeling approach forces you to consider exterior geometry and interior geometry at the same time. You end up having to clean up detail mismatched intersection by using lots of Delete Face. I don't think this is the right approach to tackle the design.
I would first create the exterior surfaces. Stitch them into a quilt and thicken it to the desirable thickness. Then add detail geometry on the interior side. Delete Face is more like a clean-up tool of last resort. It should not be used as a primary design tool. When it is used extensively, it usually means something isn't done right.
Thanks again!
