Adding layering
Adding layering
mathewbutterfield
Adding layering
mathewbutterfield
Hi there can you tell me if you can add layering in fusion 360 so I can draw a floor plan of my house and add a layer for things like windows and doors which can be turn on/off. I hope youcan understand my question.
Thank you
Mathew
g-andresen
You don't need layers for that.
For each feature you create a sketch on its own plane.
For the floor plan e.g. on XY, 1st floor > offset from xy, doors on X or Y / Z etc.
The individual sketches are activated as needed.
günther
mathewbutterfield
Hi thank you for your reply I would like to do other things with the layers like each wall as a layer or can I do that with xyz Planes.
I would like to then view it from autodesk viewer and do other things as well
Thank you
Mathew
TrippyLighting
There are no 2D layers in Fusion 360.
davebYYPCU
Treat each sketch as a layer if you need them.
Might help.....
wersy
I assume @mathewbutterfield is used to AutoCAD. There you can assign any sketch element to a layer and also give it a colour. So you can show and hide them, for example, which is necessary when working with AutoCAD.
@mathewbutterfield  Fusion works quite differently, you don't need layers.
