Adding an edge to the rim of a pot, to extrude
claudio-delucaEBP8L
claudio-delucaEBP8L
So ive created this form that i want to add a rim to, and im not sure how to add an edge to the face of the form so i can extrude it and create rim for a lid.
to briefly go over what im trying to do, I created a form, and split them by running an unusual plane through them. then i want to add rims to all of them so they all can refit together. (hope thats not to confusing to understand). i created a more simplified form which will show you what i mean (see photos). Thank you
Screen Shot 2019-07-08 at 18.31.02.pngScreen Shot 2019-07-08 at 17.59.28.pngScreen Shot 2019-07-08 at 16.38.57.pngScreen Shot 2019-07-08 at 19.56.34.png
TheCADWhisperer
Can you File>Export and then Attach your *.f3d file here?
Are there any unresolved issues in your timeline (yellow or red highlights)?
jeff_strater
I think you want to use Sweep to do this.  Here are a couple of threads that illustrate it on simple geometry:
create-lip-groove
how-to-cut-a-lip-into-the-sidewalls-of-a-box
Jeff Strater
Engineering Director
claudio-delucaEBP8L
Hi, nothing i can see in the timeline is red or yellow.
TrippyLighting
Here is one approach:
In the screencast I forgot to include the 2 bottom surfaces when thickening, but that is corrected in the attached model.
claudio-delucaEBP8L
hey, thank you! i've done some playing with your technique and it works pretty well, i'm going to keep experimenting, but this is a great method. I appreciate you taking the time to show me!
