Component too thick
Component too thick
Component too thick
I HAVE  A COMPONENT THAT IS TOO THICK.  cAN i MAKE IT THINNER, AND HOW?
TheCADWhisperer
No actionable information given.
Please File>Export and then Attach your *.f3d file here?
I nee to make it 10mm thick.
stevesneadH8U9D
If it is a linked component open the file that contains it and modify it there. Otherwise make sure you are working at this components level by activating the "fish eye". From there you can shave off whatever you need to on the body in question using extrude/cut operation.
TheCADWhisperer
@Anonymous wrote:
I need to make it 10mm thick.
What is preventing you from making it 10mm thick?
Attach your file here and end all doubt.
