A shape that is impossible to draw in Fusion360
saulius1005
Message 1 of 11
saulius1005
I'm trying to draw a hole of this shape in a cylinder, but it looks like creating such a 3D shape will take at least half a day. I tried both spline options, conic curve, and arc.
With the fitpoint spline, it almost works, but in that case, the front shape doesn't come out right, and the circle becomes not quite round.
Replies (10)
Message 2 of 11
TrippyLighting
Dead easy!
Message 3 of 11
saulius1005
How did you do that? Wait, it’s not working for you either.Ekrano kopija 2025-01-30 221749.png
Message 4 of 11
TrippyLighting
If you download the design file I had attached to my message, you can roll it back all the way to the beginning and then forward step by step.
That explains how the design was constructed.
I can create a screencast if you still have questions.
Message 5 of 11
TrippyLighting
If you edit the sketch and reduce the angle, what do you observe?
Also, the geometry in your sketch is impausible and does not reflect the actual physical part.
The views in your sketch contradict each other!
Message 6 of 11
saulius1005
Here’s what I mean. If I use a spline, everything has to be done manually. That is, each point needs to be moved along the XYZ axes until it somewhat resembles an arc or a circle (depending on the viewing angle—top, side, or front). But maybe there's a way to ensure that a circle stays a circle, an arc stays an arc, and the front view is a perfect 90-degree angle instead of something that just roughly resembles these shapes, like it does now.
Message 7 of 11
saulius1005
Here is the real part and its view from the top, side, and front.toptopfrontfrontsideside
In reality, forming this part took 1 minute in the Fusion program...
Message 8 of 11
KristianLaholm
This is what I see in your design intent.
The Front and Side view in your drawing doesn't add up for me, one of them feel rotated.
Message 9 of 11
TrippyLighting
Spot on. That little radius the OP left out of his simplified paper/pencil sketch makes all the difference.
Message 10 of 11
g-andresen
This is how I would do it
günther
Message 11 of 11
saulius1005
Thank you all for your help! I finally managed to draw this shape! Thanks again!
