A custom gear shape design
- Mute
- Permalink
- Report
Hi All, I'm wondering if anyone can give me any input on creating a simple custom gear/arrangement that I can change parametrically. The goal being to be able to change the tooth count and shape of teeth on the fly without having to redraw everything over and over. Im just not that good yet at constraints and perametics ; {
2nd requirement is that the gear shape needs to be pretty close to what I have already, as the larger gear is actually a thumbwheel that will be turned by your thumb to make setting changes to a machine. SO the gear needs to feel confortible when turning by your thumb or finger.
3rd requirement is the final gears need to be CNC machined from top and bottom ONLY in aluminum and are quite small so I will need to finish with 1/8 end mill to get into the pocket without any axial undercuts of the gear teeth.
Any input would be appreciated.
