3D print export utility behavior changed in latest Fusion release
alpierce
Message 1 of 11
alpierce
In the previous versions of Fusion I could send stl files directly to Prusa Slicer whether it was already open or not. Multiple exports would place multiple objects on the plater for printing simultaneously. The newest version will only place objects if Prusa Slicer is not already running. It will launch Prusa Slicer, as it should, and the object will appear on the plater as expected. However, if a second object is selected and sent to Prusa Slicer it never appears on the plater. The result is an export one object, slice, send to printer que, quit Prusa Slicer, export a second object, slice, send to print que, rinse and repeat work flow. Not sure if it’s a Fusion problem or a Prusa Slicer problem , running the latest versions of both on macOS.
Fusion 2.0.20256 arm64 [Native]
Active Plan: Subscription
macOS 14.6.1 (23G93) on Mac14,13
Prusa Slicer Version 2.8.1+MacOS-arm64
Replies (10)
Message 2 of 11
g-andresen
If you had looked at one of the many posts on this topic, you would have realised that there is a ticket for it.
This means that the problem is being worked on.
Günther
Message 3 of 11
alpierce
Yes, I am aware of that now. There were several posts on the bugs forum. I wasn’t sure if it was a bug, or perhaps a problem with my new version of Prusa Slicer. There were significant changes to both pieces of software. Thank you for responding.
Message 4 of 11
it2YB2F
Observer
Observer
Same here. It's very frustrating!
Message 5 of 11
g-andresen
take a look here   > # 4 by @seth.madore
günther
Message 6 of 11
lukas.fuhrmann
The issue has been fixed and a new update for Fusion was deployed last night. So please update your Fusion and you should be able to use your 3d printing workflows again.
Lukas Fuhrmann
Product Owner Additive Manufacturing
Message 7 of 11
alpierce
Excellent!
Message 8 of 11
jasonK6UNF
Community Visitor
Community Visitor
My Fusion says that it is "Up to date" as of 2 days ago. October 12, 2024. I'm having the issue where it's pushing me to Manufacturing like I'm creating CAM. I printed on Friday just fine, now today, it's not working. According to this thread, the latest release is fixed, but not for me. Any suggestions?
Message 9 of 11
alpierce
Mine is working normally still.
Fusion 2.0.20460 arm64 [Native]
Message 10 of 11
jasonK6UNF
Community Visitor
Community Visitor
Fusion 2.0.20476 arm64 [Native]
macOS 15.0.1 (24A348) on MacBookPro18,2
Mine appears to be slightly newer on the version. Bug creep back in? I'd ask you to update and test but I wouldn't want you to deal with the issue.
Message 11 of 11
alpierce
I will eventually update and will let you know what happens.
