2D Drawing fuzzy/ messy lines
ryan_kirkN5LME
Message 1 of 31
ryan_kirkN5LME
Screenshot 2023-12-05 172634.pngI am trying to get a drawing but anytime I load the file into a new drawing it shows up like this even when zooming in. It fixes itself when I zoom far out. My graphics card is up to date and so is Fusion I am not in a custom drawing template either which I know are both issues.
I have a RTX 4070 Geforce and a intel i9
Replies (30)
Message 2 of 31
jhackney1972
Please attach just your MODEL so the Forum users can create a 2D Drawing and see their results.  From this they may be able to advise you.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
Message 3 of 31
ryan_kirkN5LME
Here is the file
Message 4 of 31
ryan_kirkN5LME
I have posted the file below
Message 5 of 31
jhackney1972
I do not see any attached file.  Please know you must attach it using a Forum post, you cannot use email.
Message 6 of 31
ryan_kirkN5LME
It had not posted my mistake
Message 7 of 31
ClintBrown3D
Hi @ryan_kirkN5LME
fuzzy graphics are usually caused by the graphics card driver being out of date. Windows update sometimes rolls back driver versions (particularly AMD for some reason).
try updating your graphics card driver.
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
Message 8 of 31
ryan_kirkN5LME
I have already checked that and I am fully up to date
Message 9 of 31
jhackney1972
It still would be nice for your to attach a problem MODEL file for the Forum users to test.
Message 10 of 31
ryan_kirkN5LME
I did send the “problem” file I opened it on another computer and it was fine the issue is my computer shows it as fuzzy or glitchy so sending the “problem” file is not possible
Message 11 of 31
ClintBrown3D
Hi @ryan_kirkN5LME
The fuzziness is definitely graphics related. Can you share a DXDIAG from your PC setup?
Clint Brown
Message 12 of 31
ryan_kirkN5LME
Where would i find that
Message 13 of 31
ClintBrown3D
Hey @ryan_kirkN5LME
"The fuzziness is definitely graphics related. Can you share a DXDIAG from your PC setup?"
Click here ----> DXDIAG
Clint Brown
Message 14 of 31
ryan_kirkN5LME
Operating System: Windows 11 Home 64-bit (10.0, Build 22621) (22621.ni_release.220506-1250)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: XPS 15 9530
BIOS: 1.8.0 (type: UEFI)
Processor: 13th Gen Intel(R) Core(TM) i9-13900H (20 CPUs), ~2.6GHz
Memory: 32768MB RAM
Available OS Memory: 32440MB RAM
Page File: 20006MB used, 17296MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 240 DPI (250 percent)
System DPI Setting: 240 DPI (250 percent)
DWM DPI Scaling: UnKnown
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Supported
DirectX Database Version: 1.4.7
DxDiag Version: 10.00.22621.0001 64bit Unicode
Message 15 of 31
ClintBrown3D
Hi @ryan_kirkN5LME
Thanks for that. Unfortunately, there is not enough information in that data. To help you, I need a DXDIAG to see all of your graphics driver information.
Clint Brown
Message 16 of 31
ryan_kirkN5LME
Here it is
Message 17 of 31
jhackney1972
Give this a try, open your drawing, go to Document Settings in your Drawing Browser and on the first tab, change you Line Width Group to Medium.  Also before clicking OK, place a check in the box beside Display Line Widths.
Message 18 of 31
ryan_kirkN5LME
Have those settings already no difference I even tried changing the widths and there was no change
Message 19 of 31
ClintBrown3D
Hi Ryan
Try installing the latest graphics driver here: https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
Clint Brown
Message 20 of 31
ryan_kirkN5LME
Is this the latest for my graphics card?
