**** stuck again
**** stuck again
gpetti20
Message 1 of 18
**** stuck again
gpetti20
Guys, I have been trying to get the attached sketch to process thru the 2D profile so I can cut it out on my plasma table. Icankind of get the inside to show up for the tool path but it takes like 4 hours and when it does it looks like It wants to cut at every point (start and stop the move then goes to the next dot).
I cannot get the outer contour to show up any way I try it. to complete the cut out. I have tried extrusion, picking each item, and nothing works. I am sure I have or have not done something right. 😞
Please advise if you can. P.S. is anybody having problems wht Fusion 360 running real slow in the last few days?
Glenn
Replies (17)
Message 2 of 18
simsworx
Glenn,
   Looking at your sketch, there are numerous issues present. Focusing on the outer profile, at the lower left corner, you can double click and it will select a partial profile. The areas where it stops are where you need to fix the sketch. In particular, white dots and double lines. I found that there were numerous double line issues while working up the right hand side. Select the geometry you want to keep, delete the rest.
Did you draw this or convert this? Or was it a purchased .DXF?
Message 3 of 18
gpetti20
Purchased DXF file with 9 eagle flags in it. still having a hard time separating each one into its own separate file .
Driving me crazy
Message 4 of 18
etfrench
That sketch is definitely a mess (technical Fusion 360 terminology)😀
Replacing the top of the flagpole with a 3 point circle and deleting the splines will allow you to extrude the main outline.
ETFrench
Message 5 of 18
etfrench
Use the Divide and Conquer method to find breaks in sketch.  It is simply draw a line to bisect the sketch.  If one profile turns blue, then either move the line into the white or draw a new line bisecting the white.
Plasma and lasers don't like overlaid lines, so once you have fixed the boundary issue, extrude it.  Next, create a sketch and project the face to the sketch.  This should give you a good clean sketch to send to the plasma machine.
ETFrench
Message 6 of 18
Warmingup1953
Can you share that .dxf?
Message 7 of 18
jeff_strater
The other thing I noticed is that this sketch is a LONG way away from the origin.  About 200 feet away.  Do a "fit" and you can see how far away it is.  I'm not sure if that is contributing to your problems or not, but it is definitely not a good state for a model to be in:
Jeff Strater
Engineering Director
Message 8 of 18
gpetti20
See if this opens
Glenn
Message 9 of 18
gpetti20
Try this
Message 10 of 18
gpetti20
I did rescale it to around 21 inches
Message 11 of 18
gpetti20
I used this method for this sketch and it worked fine. fixed a lot of issues. still cannot get it to the finish line
Message 12 of 18
Warmingup1953
Here's my incomplete go...I think I have one element (cut) still to get in order...(ill play again loter today)Screenshot 2023-12-06 101427.png
Message 13 of 18
gpetti20
Man, I don't know what you did but that is exactly what I am trying to do. I guess my 63 year old mind cant figure it out.
Glenn
Message 14 of 18
Warmingup1953
My 69 Y and 361 Day old brain told me to cheat and use CorelDraw! That last element still missing is a complete PITA!
Message 15 of 18
gpetti20
That last element still missing is a complete PITA!??? is this an element I am missing or just read between the lines :):):)
Glenn
Message 16 of 18
Warmingup1953
Ok I had to fudge a bit more and it's by no means perfect but hopefully acceptable
Message 17 of 18
etfrench
What was the problem?
ETFrench
Message 18 of 18
gpetti20
Thank you Sir. You fixed my headache. This cut out perfect .
Glenn
