- Mute
- Permalink
- Report
How can I set the extend command back to extend (click on object) to extend then (click to where)?
1. What is the application?
You are in the Fusion 360 Forum.
2. If it is about Fusion 360, please show in a screenshot what you want to achieve.
günther
My Apologies, just a simple extend command, before i could click line i wanted to extend and to where.....and now in 2021, I have to select a "boundary" , wondering if it can get changed back to old way
Its a Polyline that i am trying to extend....new way in 2021 has it to select a boundary...im trying to see if it can be set back to old way
Fusion 360 cloud based (you should have latest version "online work") .so you can't get the versions before
to the best of my knowledge, sketch extend has not changed in a very long time. The interaction has always been to hover over a curve, the preview extension will be highlighted in red, and clicking will extend that curve to the next intersection (virtual or real)
