rotate wrong!
rotate wrong!
t_lamourine
rotate wrong!
t_lamourine
this drives me nuts!!! with in "home view" then go into a drawing it rotate flat to the drawing face, but also rotates the "top" to the right side instead of the top... why?  this makes no sense to me and is really very annoying to have to time and again have to rotate it back!!  and yes, I have auto rotate view off in pref's!
aliobidi
Hi ,
you can use "look at " and select the face
aliobidi
and if you have 3d space mouse you can add shortcuts for views
t_lamourine
that's still something you'll have to do every time correct?  so every time I click into the sketch I'll have to set it again.. which isn't much different that hitting the rotate arrow.
I mean it makes sense to have it rotate to the top edge up when going from home to top view/sketch view. It makes nooo sense it goes to the rotated view..?  does it?  should be the Default setup!
