2 Part question on Silhouette
dfearnow
dfearnow
1st question. How do I create a 2D silhouette of my part on the construction plane 1?
2nd, Is there a way to work on different levels? Example: say I want to draw some lines for machining later, but I dont want to have it on the same plane/level as the solid. Can I move my sketch to a different level?
HughesTooling
For a silhouette press P for project and set the selection filter to bodies.
To sketch on a different level, right click on a plane or surface and select Offset Plane. Also look at the Construct menu for more option creating planes.
Mark
Edit. Create your plane before creating a sketch, there is an option to redefine sketch planes but you can get odd things happen if the XY are pointing in different directions on the new plane.
Mark Hughes
Owner, Hughes Tooling
